질문 두가지만 할께요.
  우선 질문 한가지는...
  sujeng.php
include("./conn.php");
$tablename="cmm_board_free";
//글 불러오기
$query="select * from $tablename where NO='$NO'";
$result=mysql_query($query,$conn) or die (mysql_error());
$array=mysql_fetch_array($result);
//백슬레쉬 제거, 특수문자 변환(html용),개행(<br>) 처리 등
//$array[name]=stripslashes($array[name]);
$array[title]=stripslashes($array[title]);
$array[memo]=stripslashes($array[memo]);
$array[subject]=htmlspecialchars($array[name]);
$array[memo]=htmlspecialchars($array[memo]);
$array[memo]=nl2br($array[memo]);
<html><title>C.M.M</title>
<script language="javascript">
function check_ok()
if(!check.title.value)
{ alert("글 제목을 입력해주세요");
   check.title.focus();
   return false; }
if(!check.memo.value)
{ alert("글 내용을 입력해주세요");
   check.memo.focus();
   return false; }
if(!check.password.value)
{ alert("비밀번호를 입력해주세요.");
   check.password.focus();
   return false; }
<form name="check" action="sujeng_ok.php" method="post" onsubmit="return check_ok();">
<input type=hidden name="page" value="<? echo $page ?>">
<input type="hidden" name=NO value='<? echo $NO ?>'>
<table width="340"  border="1" cellspacing="0" cellpadding="0" bgcolor=#FFEFFF bordercolorlight=white  bordercolordark=#E70029 align=center>
        <td width="100">회원ID</td>
        <td width="100"><input type="text" name=id size="10" maxlength="10" value='<?echo $array[member_no] ?>'></td>
<tr >
        <td width="100" >제목</td>
        <td width="200"><input type="text" name=title size="35" maxlength="50" value='<? echo $array[title] ?>'></td>
        <td width="50">내용</td>
        <td width="250"><textarea type="text" name=memo rows="10" cols="35"><? echo $array[memo] ;?> </textarea></td>
        <!--textarea에서는 value값을 사용하면 안된다--!>
        <td width="90">비밀번호</td>
        <td width="250"><input type="password" name=password size="10" maxlength="10"></td>
<table align=center>
        <td><input type="submit" value="수정" class="check"></td>
        <td><a href= "list.php?page=<? $page ?>"><input type="submit" value="목록"></a>
sujeng_ok.php
include ("./conn.php");
$id=addslashes($member_no);
$title=addslashes($title);
$memo=nl2br(addslashes($memo));
$password=addslashes($password);
$date=time();
//비밀번호가 맞는지 확인
$sql="select NO from $tablename where NO=$NO and password=$password";
$result=mysql_query($sql) or die (mysql_error());
if(mysql_num_rows($result))
        $sql="update $tablename set title='$title',memo='$memo',password='$password' where NO=$NO";
        mysql_query($sql) or die(mysql_error());
      $msg = "수정을 하였습니다.";
        echo " <html><head>
                if('$msg' != '') {
                        self.window.alert('$msg');
<meta http-equiv='Refresh' content='0; URL=list.php'>
                                </html> ";
        $msg = "비밀번호가 틀립니다.";
        echo " <html><head>
                if('$msg' != '') {
                history.go(-1);
                </html> ";
소스는 이것입니다. 그런데... 문제는... 수정해서 글을 저장하면--;;
난나고 넌 너다. <br />
<br />
그렇지 않니??<br />
<br />
아흠...
이렇게 됩니다... 글 입력 했을 때에는 잘 입력 되는데 글 수정하면 하면 이렇게 되어 버리네요--;;
이게 첫번째 질문이고.. 2번째 질문은...
코멘트라고 하죠... 제가 아래 질문 올린 걸 손병목님께서 답변 해주셨던 그런 법.... 제가 코멘트를 달려고 게시판 db에 코멘트라는 걸 따로 만들었거든요... 뭐 대충 막연하게 만든거지만(--;;)
그래서 따로 코멘트 db를 만들었는데... 연동 하는 법을 모르겠네요--;;;;
만약에 1번글 밑에 코멘트가 달리면.... 코멘트 db에는 저장이 되겠지요... 근데 그걸 1번글과 연관시키는 법을 모르겠네요....
코멘트 db에 따로 게시판 번호(NO)값을 박아 넣는걸 만들어야 할까요? 대충 생각은 나지만... 실행에 옮기기에는 어렵네요
ㅎㅎㅎ
근데 조회수 조작 방지 하는 법... 어떤 방법을 이용하면 좋을까요? 제로보드 같은 경우 한번 읽고 f5 무한 난타(?) 해도 조회수는 딱 1만 올라가잖아요. ip때문인 듯(?)... 저도 그런걸 구현 하고 싶은데... 어렵네요@_@;;
제가 만든 초 허접 게시판인데... 오셔서 보시고 고쳐야 할 부분 좀 지적해주세요....
http://www.cmmania.net/cmm/board/list.php
언제나 허접초보의 질문에 답변 해주셔서 감사합니다.
